This article describes how you can create a new check. When you create a new check, you can either manually pick the rules you wish to include in the check, or select label(s) and have the rules picked automatically based on the labels.
To create a new check:
- Go to the Checks tab and click New Check:
- The New Check page opens:
- Add a title to your check.
- Add a description to your check to describe how and when this check is to be used (optional).
- Select a collection for the check.
- Select if the check is based on rules or labels. See more details below.
New Check Based on Selected Rules
When you create a check based on selected rules, you need to manually pick the rules you want to include in the check. To create a new check based on rules:
- Content: Select Selected rules:
- Add one or more rules to your check by ticking the box(es) on the left. You can use the filters above the list to filter the list of rules:
- When you’ve added the rules you want to include in the check, click Create with selected rules.
- The check you created appears on the list of checks.
New Check Based on Selected Labels
You can assign labels to rules, and then utilize these labels when you create new checks. When you create a check based on selected labels, the rules included in the check are picked automatically based on the label(s) you select to be included in the check.
When you select a label for the check, all rules to which the label has been assigned are included in the check. If you select multiple labels, a rule needs to have all the selected labels that have been selected to be added to the check. The rule may also have other labels assigned to it as well. For example: if you select the labels Architecture and Germany, any rule that has (at least) both these labels is added to the check.
To create a new check based on selected labels:
- Content: Select Selected labels:
- To add labels to be included in the check, click + next to Labels:
- The Add labels dialog opens. Select the label(s) you wish to add by clicking Select:
- When you’ve selected the label(s), you can close the dialog by clicking X:
- The label(s) you’ve added are shown under Labels.
- Click Create with selected labels. The check is created and you can see the rules included in it:
