This article describes how you can add more rules into an existing check. What are the editing rights?
- Editing Check Details
- Adding More Rules into a Check Based on Selected Rules
- Adding More Rules into a Check Based on Selected Labels
- Go to the Checks tab.
- Click the title of the check you wish to edit.
- The check details page opens. Click Edit:
- The Edit check dialog opens.
- Click Save.
To add rules to a check:
- The check details page opens. Click Add more rules:
- Select the rules you wish to add to the check and click Add selected rules to the check:
- The check is now updated with the new rules.
If you wish to add more rules into a check that is based on the selected labels, you need to either add more labels or assign the selected label to more rules. To add more labels:
- Under Labels included, click Add a label:
- A dialog opens. Select the label(s) you wish to use and click X to close the dialog:
To add new labels from the same dialog, click Add new label and follow the instructions here. Note that you need to then assign the label to one or more rules to update the check content.
- The labels included is updated, as is the list of rules.
