If you need to change the target title or criteria, you can edit the target. You can only edit targets you have created yourself. However, if you wish to edit a target someone else has created, you can duplicate the target and define the target criteria according to your needs (see Duplicating a Target).
If you edit the target criteria and the target is used in a rule, it changes the checking results.
To edit a target:
- Go to the Targets tab.
- Click the target on the list:
- The target details page opens. In the top right corner, click Edit.
- The Edit target page opens. You can now edit the target title, description, labels, IFC Schema version, IFC Entity, and target criteria:
- To save your changes, click Save changes.
