This article describes how you can edit a rule in Solibri Inside Editor. Note that you can only edit rules you have created yourself. However, if you wish to edit a rule someone else has created, you can duplicate the rule and define the specifications and requirements according to your needs (see Duplicating a Rule).
If you edit the rule requirements and the rule is used in a check, it changes the check results.
To edit a rule:
Go to the Rules tab.
Click the rule you wish to edit on the list.
The rule details page opens. Click Edit:
The Edit rule page opens. You can now edit the rule title, description, labels, IFC Schema version, target(s), IFC Entity and rule requirements. The rule requirements depend on the rule type used for the rule.
You can also edit the error text related to a rule requirement (the error texts vary depending on the rule type:
To save your changes, click Save changes in the bottom right corner of the page.
