Duplicating a rule is a fast and easy way to create new rules. When you duplicate a rule, all the rule details, except the title and description, are copied into the new rule. You can then edit these by, for example, changing the target or rule requirements. In this way, you can easily create similar rules for different purposes.
For example, if you have a door clearance rule that checks for door clearance on external doors, you can copy the rule, change the target to internal doors (you would, of course need to have an Internal Doors target) and, if needed, change the clearance requirements.
To duplicate a rule:
Go to the Rules tab.
Click the rule you wish to duplicate.
- The Rule details page opens. Click Duplicate:
The Duplicate rule page opens. Give the rule a title and change the details. For more information, see Creating a New Rule.
- Click Save changes.
